AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Bosch Nexxt 100 Series finished/spin/wash lights flashing
The machine just flashes finished/spin/wash lights and nothing happens. I tried unplugging then plugging in then holding down the rinse and delay button with one hand and turning the dial to cold/warm with the other and didn't get any results. I tried this a few times. I recently changed the boot gasket and it seems too coincidental for this to happen the next day. When I changed the boot gasket I had to take off the counter weights on the front of the machine. Could I have screwed something up when I changed out the boot gasket? What do these flashing lights mean? Thank you for any help you can give!
Dan
Unplug your machine, then plug it back in. Hold down the rinse and delay buttons with one hand. With the other hand, switch the dial from off to cold or warm or whatever cycle you want. All the buttons flash a few times, then just the start button flashes.
Washer Repair
