6 Pages«<23456>
pypeAttiche
#31 Posted : Monday, July 29, 2013 4:50:34 PM(UTC)
pypeAttiche
Good day!
I've recently spotted amazing
hoodia
pypeAttiche
#32 Posted : Monday, July 29, 2013 4:54:17 PM(UTC)
pypeAttiche
Hi!
hoodia
pypeAttiche
#33 Posted : Monday, July 29, 2013 4:55:27 PM(UTC)
pypeAttiche
Good day!
I've recently found brilliant
hoodia
pypeAttiche
#34 Posted : Monday, July 29, 2013 4:57:12 PM(UTC)
pypeAttiche
Good day!
I've recently discovered faboulous
hoodia
pypeAttiche
#35 Posted : Monday, July 29, 2013 4:57:59 PM(UTC)
pypeAttiche
Hi everyone!
I've recently come across astomishing
hoodia
pypeAttiche
#36 Posted : Monday, July 29, 2013 4:59:11 PM(UTC)
pypeAttiche
Hello everyone!
Look on this brilliant
hoodia
Joe / APP Team
#37 Posted : Tuesday, July 30, 2013 5:53:43 AM(UTC)
Joe / APP Team
Originally Posted by: Joe / APP Team Go to Quoted Post
Ok, you need to keep in mind, the control will reset, after the reset, the unit will work, advance, and operate properly one (1) cycle, the next time the cycle is used, if the issue still exists, you'll get the flashing LED, again.
pypeAttiche , We are unable to reteive your post
" pypeAttiche has just replied to a thread you have subscribed to entitled - Whirlpool Quiet Partner ii clean light flashing - have reset, still flashing - in the Dishwasher Repair forum of Appliance Repair Forum."
Could you please re post your inquiry, Thanks
jfeagans
#38 Posted : Sunday, March 23, 2014 6:45:46 AM(UTC)
jfeagans
Hello,
I noticed how old this thread is so I hope someone will be able to give me advice. I too have a Whirlpool Quiet Partner III and went through the diagnostic suggested in this thread. I still get the 7 blinking lights on the clean light. I'm thinking this may be the heating element but want to make sure before ordering. Can someone please walk me through this diagnostic process to determine what is not functioning? Model# GU2500XTP83
Jim
Joe / APP Team
#39 Posted : Monday, March 24, 2014 5:25:23 AM(UTC)
Joe / APP Team
Originally Posted by: jfeagans Go to Quoted Post
Hello,
Jim
Jim, The first thing to check is the water temperature in the tub, at the end of the initial fill cycle. It has to be a minimum 120 dgrs.F. If the water isn't hot enough, the heater and sensor can heat the water, but if the sensor doesn't produce the correct resistance, then the clean light will flash.
The information in the previous posts still apply, you'll need to check for "closed" circuits at the heater and the hi limit thermostat with a meter, and check the wiring.
The attached tech data sheet, will help with the resistance tests, and you can program into the test mode and reset the control eeprom memory.
File Attachment(s):
Tech%20Sheet%20-%208535451.pdf (168kb) downloaded 40 time(s).
jfeagans
#40 Posted : Saturday, March 29, 2014 2:40:12 PM(UTC)
jfeagans
Joe,
Thank you for all your guidance & help. It was only the heating element and I have one ordered and should be up & running as soon as it arrives.
Again, many thanks
Jim
Guest (4)
6 Pages«<23456>
