hooker
#1 Posted : Friday, March 21, 2014 3:02:52 AM(UTC)
hooker
My food in frig is freezing. The defrost fan is running, the freezer is set on warmest temp and so is the frig set on warmest temp, I have cleaned all dust from coils. Any ideas
hooker
#2 Posted : Friday, March 21, 2014 3:05:53 AM(UTC)
hooker
I went to turn off freeze and frig with temp control inside above door and I think the compressor is still running with both controls in the off position
#3 Posted : Friday, March 21, 2014 3:32:31 AM(UTC)
Sounds like the control thermostat is shot.
Contacts welded together.
To confirm this you could unplug the unit and one wire at the thermostat.
Then measure across the thermostat contacts.
With it set to Off it should be infinite ohms.
Part number: AP3882436
Frig items freezing up (Refrigerator & Freezer Repair)
by hooker 3/19/2014 4:07:23 PM(UTC)
