AP4433343 CONTROL-ELECTRICAL (316562010)
I just ordered my third expensive control panel for this range. The board keeps burning out where the power leads connect that feed the elements. Is this a bad design or do I need to do something different when hooking up the terminals? Is there any type of grease that may reduce the heat at the connection? Or should they be soldered instead?
Model # of Range: FGEF3056KFF
