peterkirt
#1 Posted : Wednesday, March 19, 2014 3:55:54 AM(UTC)
peterkirt
When I press the start button, I get a loud buzz from the timer switch and no attempt to start. The push start button checked out okay. I am assuming the timer is toast. Prior to this, the heat output and drum rotation was fine. I just thought I would check this with you folks before I start throwing parts at it !
#2 Posted : Thursday, March 20, 2014 1:45:39 AM(UTC)
Here are your parts. Includes a wiring diagram with a timing chart.
Parts for Maytag SDE3606AYW Dryer - AppliancePartsPros.com
It does sound like a timer problem as long as you are sure that it is the timer or end of cycle buzzer that is buzzing.
You could check the timer contacts with a meter to confirm this.
The reason this is important as sometimes the main motor will buzz if it does not start.
peterkirt
#3 Posted : Thursday, March 20, 2014 7:09:35 AM(UTC)
peterkirt
Thanks ...
Guest (4)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Old whirlpool electric dryer won't start (Dryer Repair)
by era300 1/22/2015 9:10:42 AM(UTC)
GE Electric Dryer won't start (Dryer Repair)
by brosnan 12/13/2014 2:08:12 PM(UTC)
Kenmore 70 Series Electric Dryer Won't Start (Dryer Repair)
by rdtraverse 12/26/2012 6:31:15 PM(UTC)
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
Kitchen Aid Electric Dryer Won't Start (Dryer Repair)
by ihtractor 6/14/2012 8:55:11 PM(UTC)
by cakst35 4/16/2012 8:40:32 AM(UTC)
trouble shooting electric dryer won't start (Dryer Repair)
by Domenic711 2/7/2012 12:33:50 PM(UTC)
Maytag Electric Dryer Won't Start (Dryer Repair)
by Rosebud42 1/6/2012 2:50:38 PM(UTC)
Electric Dryer won't start has power (Dryer Repair)
by coxc6419 11/25/2010 7:12:40 PM(UTC)
Maytag neptune electric dryer won't start (Dryer Repair)
by area123 7/8/2010 11:22:10 AM(UTC)
by fridayauction 6/1/2010 7:57:14 AM(UTC)
by WhittierM 1/8/2010 1:29:33 PM(UTC)
GE electric dryer won't start (Dryer Repair)
by aqrose 11/29/2009 2:52:05 PM(UTC)
Maytag Electric Dryer won't start,no sound (Dryer Repair)
by Pennell 11/12/2009 5:29:58 PM(UTC)
