patrickjwoods
#1 Posted : Sunday, March 16, 2014 10:57:47 AM(UTC)
patrickjwoods
Rank:: Member
So my wife dropped a vacuum attachment down the lint chute, and proceeded later that day to operate the dryer (I know...).
It's a Maytag stackable/combo #MET3800TW2
Needless to say, the blower wheel was obliterated. Replacing the wheel itself was fairly painless, but now the dryer won't produce heat.
Is it possible that the the thermal cut out fuse was blown when the blower was initially jammed?
This part: http://www.********************...1?modelNumber=MET3800TW2
mr_mjsjr
#2 Posted : Sunday, March 16, 2014 1:34:06 PM(UTC)
mr_mjsjr
1. reset your breakers (one side could trip and the motor could still run, but no heat) 2. make sure you did not leave a wire off 3. thermal fuse or hi limit may have been damaged (unable to remove hot air w/o blower causing unit to over heat - ohm out to be sure) 4. some electric units run power through the run winding to the heater (could have been damaged during dramatic stop)
#3 Posted : Monday, March 17, 2014 1:46:33 AM(UTC)
Parts for Maytag MET3800TW2 Washer Dryer Combo - AppliancePartsPros.com
See the attachment for a wiring diagram.
It is for a MET3800TW0 but with luck will be a close match to your unit.
First check your power to be sure you have the 220 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
If the power is OK.
Set the timer to a timed dry, high heat, mid cycle.
Set your meter to the most sensitive resistance scale. Short the meter leads together before starting so you can see it there is a zero offset in the meter.
Unplug the unit.
Attach one meter lead to the L1 prong on the line cord and leave it there.
Now work your way back through the heater circuit.
BK (black) on the timer should be 0 ohms.
R (red) timer switch 2 should be 0 ohms.
Both sides of the operating thermostat contacts (reds)should be 0 ohms. The violet wires inside connectors are the thermostat's internal heater so you can ignore them.
Both sides of the thermal fuse should be 0 ohms.
Both sides of the thermal cutoff should be 0 ohms.
Both sides of the hi-limit should be 0 ohms.
One side or the heating element should be 0 ohms.
The other side of the element should be around 8 to 12 ohms.
Also 8 to 12 ohms at 1M on the motor's centrifugal switch.
There you have now checked most of the heater circuit except the centrifugal switch and the wire from it to L2.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
MET3800.pdf (389kb) downloaded 0 time(s).
