Close the door within 5 seconds hit the heated dry, then normal buttons, then hit cancel. Computer should reset.
Problem originated with low temperature water, just check.
If this fails to work, you have a stuck keypad, probably warped, just order a new one, or you can unplug keypad ribbon cable, clean and re-install.
