The top burners and broil element work properly. The clock, touch pad, digital readout, etc. all work properly. The bake element does not come on at all and the convection element will only warm the oven to about 150 degrees. The elements were tested and have the correct resistance. Is this more likely a problem with the electronic control board or the power board?
