I have determined that the fuse on this hood is probably blown. Green indicator light comes on but fan and light do not. Problem is I can't find where the fuse is. I have taken off the screen filters and the metal base. Any idea? A diagram or picture would really be helpful.
Originally Posted by: LisaRobyn  I have determined that the fuse on this hood is probably blown. Green indicator light comes on but fan and light do not. Problem is I can't find where the fuse is. I have taken off the screen filters and the metal base. Any idea? A diagram or picture would really be helpful. Lisa, did you get any feedback on how to fix this problem with the hood range? I'm having the same problem.
