smammi9
#1 Posted : Friday, February 28, 2014 8:23:23 AM(UTC)
smammi9
I have a kenmore oven model # 665.75801001 that will not self clean. MY locking mechanism does not work but i can manually lock and unlock my oven door when i lift the lid. I can lock the door and start the self cleaning. The oven will turn on and start for about 30 seconds and then shut off and display an E1 -F5- error code. When the self cleaning first starts everything looks normal, all the info is displayed on the screen including the locked and clean.
festeraddams
#2 Posted : Friday, February 28, 2014 5:48:30 PM(UTC)
festeraddams
More than likely you have a bad door latch or bad door light switch?
#3 Posted : Saturday, March 1, 2014 2:01:45 AM(UTC)
Parts for Kenmore Range 66575801001 - AppliancePartsPros.com
If you go to the Sears parts site they have part breakdown diagrams.
Unfortunately these are not available to other part vendors but the part numbers will cross reference to APP numbers.
The attachment may be useful to you.
File Attachment(s):
75801001.pdf (557kb) downloaded 20 time(s).
smammi9
#4 Posted : Tuesday, March 4, 2014 6:26:27 PM(UTC)
smammi9
replaced the door latch actuator. problem solved. thanks
