I have a kenmore oven model # 665.75801001 that will not self clean. MY locking mechanism does not work but i can manually lock and unlock my oven door when i lift the lid. I can lock the door and start the self cleaning. The oven will turn on and start for about 30 seconds and then shut off and display an E1 -F5- error code. When the self cleaning first starts everything looks normal, all the info is displayed on the screen including the locked and clean.
More than likely you have a bad door latch or bad door light switch?
Here are your parts Parts for Kenmore Range 66575801001 - AppliancePartsPros.comIf you go to the Sears parts site they have part breakdown diagrams. Unfortunately these are not available to other part vendors but the part numbers will cross reference to APP numbers. The attachment may be useful to you. |
THIS FORUM IS DEAD!!!!!!! |
replaced the door latch actuator. problem solved. thanks
