scottnic
#1 Posted : Wednesday, February 19, 2014 2:10:46 PM(UTC)
scottnic
My washer fills with water, then sits there (no noise at all) for several minutes, then drains. There's no agitation whatsoever (and no indication that it's even trying to agitate).
I'm a novice when it comes to appliance repair, but I'm pretty handy with tools and really good at following instructions. How do I start diagnosing the problem?
fairbank56
#2 Posted : Wednesday, February 19, 2014 3:19:19 PM(UTC)
fairbank56
Groups: Expert
Most likely the timer which is no longer available except through third party Internet vendors. Timer part number is 22002828. You can try a test to confirm. After washer has filled and should be agitating, place a jumper wire between ground and the blue wire terminal on the back of the 4-button cycle switch.
Eric
scottnic
#3 Posted : Tuesday, February 25, 2014 10:58:12 AM(UTC)
scottnic
Originally Posted by: fairbank56 Go to Quoted Post
...place a jumper wire between ground and the blue wire terminal on the back of the 4-button cycle switch.
Grounding the blue wire did indeed start the agitation cycle.
It looks like a new timer would set me back $175—quite a bit when I only paid a couple hundred for the washer/dryer set (used) a couple years ago... But I found a used timer on ******** for $35. Hopefully it'll do the trick.
Thanks for your help!! :)
