Complaint: The Displays For Frezzer & Refrigerator Start Blinking And Cooling Stops. Once The Power Disconnected And Reconnect The System Starts Functioning. It Recur Almost After 4 To 6 Hours. Replaced The Pcb. The Fault Remains. Replaced A Blown Out Thermal Fuse In The R-evaporator. The Blinking Symptom Stopped. The F-room Keeps -19 Degree Perfectly. The R-room Display Shows 3 Degree, But The Actual Temperature Varies From 3 To 14 Degrees.
What Could Be The Reason? Thnx Joseph Pj
