kensgranam
#1 Posted : Friday, January 24, 2014 11:11:33 AM(UTC)
kensgranam
Opened the Freezer door and got bombed with ice cubes. The ice maker is overflowing ice cubes.
What can I check other than the obvious to make sure nothing is hitting the ice maker.
Follow up :
OK I shut off the slide switch on the right switch. Still makes Ice. I looked at all the little holes where everbody talks about a light and dont see any light. The only way to stop the icemaker was to shut off the water supply to fridge.
Should I replace the emitter and sender?
HELP !!
kensgranam
#2 Posted : Thursday, February 6, 2014 4:44:37 AM(UTC)
kensgranam
Well no body answered me so I decided to just get the Emmiter and reciever parts. I changed them , took about 10 minutes including time to walk in garage and get the tools.
Problem solved !!!!!
Kenny
getting to much ice when pushing actuator (Refrigerator & Freezer Repair)
by Bobdpt 8/3/2014 2:08:40 PM(UTC)
To Much Ice (Refrigerator & Freezer Repair)
by EdwardLKip 7/28/2011 10:24:05 AM(UTC)
to much ice (Refrigerator & Freezer Repair)
by djminotti 3/14/2009 10:02:43 AM(UTC)
