booie
#1 Posted : Friday, January 31, 2014 7:10:20 AM(UTC)
booie
refrigerator and freezer not cooling. Thermostat was set at factory setting. When the dial was turned up, the fan will run but will still not cool.
#2 Posted : Saturday, February 1, 2014 1:11:34 AM(UTC)
Parts for Whirlpool ET8WTKXKQ01 Refrigerator - AppliancePartsPros.com
You said "When the dial was turned up, the fan will run but will still not cool."
I do not know which fan you are referring to. There are twa fans in the unit.
Also I am assuming that the unit then runs continuously except when it may go into a defrost cycle.
When set to a colder temperature the evaporator/freezer fan, the condenser/compressor fan and the compressor should come on as they are wired in parallel.
You can usually hear the compressor but also should be able to feel it vibrating.
The first thing to do is determine if the compressor is on.
If on it could be a sealed system problem (little or no frost on the evaporator coils) or a defrost problem (coils heavily iced/frosted over).
With a defrost problem you will get some cooling just not enough.
If not on could be a compressor starter problem, a compressor problem or a wiring problem.
File Attachment(s):
ET8WT.pdf (307kb) downloaded 2 time(s).
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
GE GSH25JSDDSS Not cooling or Freezing (Refrigerator & Freezer Repair)
by wag357 11/2/2019 10:24:52 AM(UTC)
Samsung not cooling or freezing (Refrigerator & Freezer Repair)
by PhillipsHouse 1/17/2016 7:11:23 PM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Not cooling or freezing (Refrigerator & Freezer Repair)
by cdgal63 8/13/2014 6:49:14 AM(UTC)
Whirlpool SBS not cooling or freezing (Refrigerator & Freezer Repair)
by Alysia111 7/21/2013 6:54:49 AM(UTC)
fridge, freezer not cooling or freezing (Refrigerator & Freezer Repair)
by tripper 6/16/2013 4:59:40 AM(UTC)
Frigidaire refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mrsmobley 6/10/2013 7:37:50 PM(UTC)
by carmonafam 3/31/2013 11:12:19 PM(UTC)
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
Frigidaire Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by cca610 11/5/2012 2:01:36 PM(UTC)
Kenmore Fridge not cooling or freezing (Refrigerator & Freezer Repair)
by seayii 7/23/2012 10:30:25 AM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
GE side by side fridge/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by Lou7 4/23/2012 8:36:19 PM(UTC)
Maytag Plus Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mangman 5/12/2011 7:04:56 PM(UTC)
