lindabeall
#1 Posted : Tuesday, January 28, 2014 8:36:49 AM(UTC)
lindabeall
My dryer makes a squeaking sound when it first starts up. I took it apart and found the right roller did not turn as freely as the left. I cleaned the shaft and inside the roller but did not help. What do you suggest? Thanks
Simon / APP Team
#2 Posted : Tuesday, January 28, 2014 12:04:07 PM(UTC)
Simon / APP Team
Groups: APP Team
Hello, Linda.
You should replace both rollers, they are identical. Here is your part:
Part number: AP4008534
There is also a chance that the belt tension pulley may squick. Here is the part:
Part number: AP4373393
Thank you.
Simon.
lindabeall
#3 Posted : Tuesday, January 28, 2014 2:33:56 PM(UTC)
lindabeall
Thanks for your quick reply. I also thought I should replace the rollers on the dryer. I just wanted a second opinion. Lind
Screeching dryer (Dryer Repair)
by timchi29 12/8/2016 8:20:27 PM(UTC)
Squeaking & screeching dryer (Dryer Repair)
by kenne53 2/8/2013 9:40:58 AM(UTC)
