Dryer rusns quiet during part of the cycle, but mostly squeals and screechs. Noises are less if washer is running at the same time. What parts are required to cure this problem.
Hello, Remove the dryer access panel and the front panel. Remove the dryer front tumbler and inspect the tumbler bearings (#12 at the diagram). If they are bad, you will need a rivet tool to install the new parts. Also inspect the rear drum support rollers and the drive belt. - The tumbler bearing kit (2 needed) Part number: 306508
