Microt
#1 Posted : 11 years ago
Microt
[FONT=Times New Roman","serif]I have a 12 year old Kenmore / Whirlpool side by side. I replaced the evaporator motor in July of 2013. I had no problems until then. It failed again in Januaryof 2014. My question is: is it going to fail again in 6 months and what can cause this. The refrigerator and freezer run fine and it does not seem to run excessively. Both times the motor had an open coil.[/FONT]
#2 Posted : 11 years ago
Below is the fan. Click on the picture for more views/info.
The fan has a different part number that the original part so perhaps they have improved it.
Part number: AP4364011
I would check that it gets 120 volts across it when running.
Low voltage can cause problems.
#3 Posted : 11 years ago
Use a SM999 universal motor, better price and they never fail. Comes with instructions.
