meppwc
#1 Posted : Wednesday, January 22, 2014 5:24:19 AM(UTC)
meppwc
My freezer froze up
We defrosted it and checked the defroster and thermostat. Both parts checked out fine.
We now want to check the defrost timer but cannot locate it.
We have looked all over in the fresh food section, behind the kick plate, and in back where the compressor is and looked at the motherboard.
I cannot find this timer anywhere, can someone help?
Cameronkrtz
#2 Posted : Wednesday, January 22, 2014 9:55:29 PM(UTC)
Cameronkrtz
I think it is located behind toe plate below door on the left side.
#3 Posted : Thursday, January 23, 2014 1:16:22 AM(UTC)
It is part of the motherboard behind a cover in the back.
Only way to force defrost is to install a wire jumper across the 3 pin power connector as labled on the board, line and def. just pull the connector when you put the jumper in. Plug fridg in, if it now defrosts, you have a bad motherboard.
Guest (5)
location of defrost timer (Refrigerator & Freezer Repair)
by simons98 2/20/2014 5:08:31 AM(UTC)
Location of Defrost Timer (Refrigerator & Freezer Repair)
by ipihandyman 8/15/2013 8:57:09 AM(UTC)
Location of defrost timer kenmore 106.8652781 (Refrigerator & Freezer Repair)
by fone_et 11/12/2011 11:34:48 AM(UTC)
Location of Defrost Timer on Amana SxS (Refrigerator & Freezer Repair)
by bfyffe07 11/3/2010 2:16:02 PM(UTC)
Location of defrost timer (Refrigerator & Freezer Repair)
by pcbob 7/5/2010 5:47:52 PM(UTC)
Location of defrost timer? Amana BR18VL - Freezer on bottom. (Refrigerator & Freezer Repair)
by virtualblues 7/5/2010 11:28:00 AM(UTC)
by Frank Cool Fuel 6/25/2009 5:47:27 PM(UTC)
Finding location of Defrost timer and thermostat (Refrigerator & Freezer Repair)
by johnnyram 6/8/2009 8:50:49 AM(UTC)
