normanb
#1 Posted : Monday, January 20, 2014 12:40:36 PM(UTC)
normanb
My kenmore washer model 110.28934790 is intermittently working during the draining and spinning cycles. One time it will work fine through the whole wash and spin cycle then the next time it will stop midway prior to the rinse cycle and not drain the water from the tub. The timer will advance all the way to the end of the spin cycle but the machine does nothing. The tub is full of water. The lid switch checks out fine. The machine isn't making any weird noises. Can it be the timer? Not sure what to check. Thanks for your help.
Kenmore Elite washer not draining or spinning (Washer Repair)
by cadrin16 3/24/2014 10:54:33 AM(UTC)
Problem with Whirlpool washer not draining or spinning out (Washer Repair)
by mywhirlpool 6/10/2011 9:49:59 AM(UTC)
GE Washer not draining or spinning, but will agitate and fill (Washer Repair)
by jcsaxx 11/22/2010 9:04:14 AM(UTC)
Frigidare Washer not draining or spinning right (Washer Repair)
by wererich 10/20/2008 4:10:01 PM(UTC)
