tom_in_atl
#1 Posted : Monday, January 20, 2014 7:44:08 AM(UTC)
tom_in_atl
Everything else seems to be working fine but the dishes are not drying.
From what I've read, it may either be the high-limit/temp thermostat or the heating element.
Are the high-limit thermostat and high-temp thermostat the same thing? Some sites seem to have the same item with different names.
How can I confirm which is the issue?
thanks.
tom_in_atl
#2 Posted : Monday, January 20, 2014 6:45:34 PM(UTC)
tom_in_atl
I removed and tested the heating element as well as the hi-limit thermostat #661566
Both tested fine for continuity.
I also tested the thermostat by placing it on a griddle.. when it heated up to about 240 degrees, the circuit opened so it seems to be working as well.
What else could be the problem?
thanks
#3 Posted : Thursday, January 23, 2014 1:37:25 AM(UTC)
Parts for Whirlpool DU920QWDQ3 Dishwasher - AppliancePartsPros.com
Using a meter check from P6 (White/Red) on the control board to White/Violet on the door switch.
If you measure the heater resistance ( about 25 ohms) then odds are that it is a control board problem.
File Attachment(s):
DU920.pdf (651kb) downloaded 5 time(s).
