dcairway
#1 Posted : Saturday, January 18, 2014 4:54:22 PM(UTC)
dcairway
first noticed freezer thawing and then realized frig wasnt cold. Neither side seem to get cold. the fan in the back comes on and the fan in the freezer behind the panel comes on, what can I check or please give me some advice
#2 Posted : Sunday, January 19, 2014 1:59:26 AM(UTC)
Is the compressor running?
You can usually hear it but you should also be able to feel it vibrating.
It should be on whenever the condenser/compressor fan is on.
dcairway
#3 Posted : Tuesday, January 21, 2014 9:59:20 PM(UTC)
dcairway
no the compressor wont start, u can hear a click and nothing, then after a few minutes sometimes another click.
dcairway
#4 Posted : Tuesday, January 21, 2014 10:06:13 PM(UTC)
dcairway
is the snall eclectrical unit mounted on the side of the comptessor a start capacitor ? or a relay or both? It is what is clicking as far as I can tell, but it doesn't click continuasly.
dcairway
#5 Posted : Wednesday, January 22, 2014 12:10:57 AM(UTC)
dcairway
ok so I pulled the start relay and overload off the compressor and it rattled and fell apart when I released the clips inside. The middle post (male end connector) attached to a separate part inside the assembly is still intact. How do I check the compressor now that I removed the relay and overload?
#6 Posted : Wednesday, January 22, 2014 1:33:47 AM(UTC)
Below is a link with how to check the compressor etc.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
Parts for ED0GTQXKQ0 - AppliancePartsPros.com
You are missing the ;last digit of the model number so will have to choose the correct unit in the Matching Model Numbers section.
Also if you do not have the wiring diagram I may be able to get it for you but you need but I need that last digit.
The compressor winding test is not definitive. In other words it will tell you that the compressor is bad but does not tell you that it is good. It may have winding to winding shorts or mechanical problems.
Same goes for the capacitor as sometimes they only fail when working voltage is applied to them. Note that they rarely fail.
There is also no good wat to check the start PTC so if the compressor checks out OK then ypouhave to replace the starter to check it.
dcairway
#7 Posted : Wednesday, January 22, 2014 10:34:59 AM(UTC)
dcairway
thank you, I will let you know how it turns out, you've been helpful. Last digit of model number is 0
#8 Posted : Thursday, January 23, 2014 12:29:19 AM(UTC)
See the attachment for the tech sheet
File Attachment(s):
ED0GT.pdf (352kb) downloaded 2 time(s).
Guest (6)
