Based on fact it won't agitate or spin, figuring it is a bad motor drive coupling? Someone mentioned it could also be the "agitator dog"?
Will appreciate comments and if it is the agitator dog, what are the steps to replace?
thanks
Groups: Expert
You ask whether the motor is running when it should be agitating or spinning and I'm not sure? It does fill properly and it does drain. Washer is not where I am now so I can't check it. It did agitate very, very slowly for about a minute until I changed the cycle, then it wouldn't agitate at all. Does this sound like the coupler?
Bill
Groups: Expert
Yes, faulty coupler could cause slow agitation.
Eric
Thanks Eric. It will probably be a week before I get the part and put it in. I'll let you know the results.
thanks again! Bill
It was the motor drive coupling. Appreciate the help.
Bill
