Nomad Terry
#1 Posted : Friday, January 17, 2014 5:23:49 AM(UTC)
Nomad Terry
Dryer wont start. When you push start button the end of cycle buzzer goes off. Changed timer motor control yesterday still still does same thing. Any ideas
fairbank56
#2 Posted : Friday, January 17, 2014 1:21:44 PM(UTC)
fairbank56
Groups: Expert
Check for 120vac to ground at timer Y-BK terminal and at GY terminal, timer on, don't have to press start switch.
Eric
Nomad Terry
#3 Posted : Sunday, January 19, 2014 6:41:28 AM(UTC)
Nomad Terry
Checked for voltage you suggested have 120 at each. Thinking the motor has gone bad or the contactor switch on the motor bad ???
fairbank56
#4 Posted : Sunday, January 19, 2014 7:35:38 AM(UTC)
fairbank56
Groups: Expert
I'm not convinced of that yet. Turn timer on to timed dry, monitor 120vac at gray wire on buzzer. Press start switch. Does buzzer sound? Does voltage drop? While holding start button in and buzzer is sounding, also check voltage at pink wire on buzzer.
Eric
Guest (6)
