revteebee
#1 Posted : Monday, January 13, 2014 5:05:00 PM(UTC)
revteebee
The dryer just stopped working. I pressed the starter button and nothing happens. No buzz, no click no nothing.
fairbank56
#2 Posted : Monday, January 13, 2014 5:55:39 PM(UTC)
fairbank56
Groups: Expert
We would need the model number to be of any help to you.
Eric
revteebee
#3 Posted : Monday, January 13, 2014 6:25:57 PM(UTC)
revteebee
Kenmore 400 is all can see.
fairbank56
#4 Posted : Monday, January 13, 2014 6:42:21 PM(UTC)
fairbank56
Groups: Expert
That doesn't help. There should be a label somewhere with model number and serial number. May be behind door.
Eric
revteebee
#5 Posted : Tuesday, January 14, 2014 7:22:45 PM(UTC)
revteebee
Mod - 110.68422700
Ser - MW4154041
fairbank56
#6 Posted : Wednesday, January 15, 2014 5:08:39 AM(UTC)
fairbank56
Groups: Expert
Check that you have power at the receptacle. If good, check continuity on the door switch and check operation (continuity when pressed) of the start switch. If good, open control panel and check that you have 120vac to ground on timer switch BU terminal with timer on. If good, remove back panel and check continuity of the thermal fuse on the blower housing. Left side with the two blue wires on it. Report findings.
Eric
revteebee
#7 Posted : Wednesday, January 15, 2014 11:11:42 AM(UTC)
revteebee
Ok will do.......thanks
Guest (4)
Kenmore Elite dryer won't start (Dryer Repair)
by Guest 6/22/2024 6:34:42 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Dryer won't start after changing fuses and timer (Dryer Repair)
by Guest 1/17/2023 11:21:44 AM(UTC)
Dryer Won't start - Repair Video (Dryer Repair)
by Guest 8/8/2021 1:55:18 PM(UTC)
Kenmore 100 Series Dryer Won't Start (Dryer Repair)
by juser 11/7/2020 4:44:16 PM(UTC)
Gas dryer won't start at all (Dryer Repair)
by GuyGreg 2/21/2018 2:26:33 PM(UTC)
Dryer won't start (Dryer Repair)
by Ginadrc 1/26/2018 7:24:30 PM(UTC)
by Petem 12/2/2017 3:27:50 PM(UTC)
Maytag dryer won't start (Dryer Repair)
by eagle243 11/15/2017 6:44:39 PM(UTC)
Dryer won't start after replacing the heating element (Dryer Repair)
by ivyholly 6/8/2017 6:45:42 PM(UTC)
Dryer Won't Start-Lights Blinking (Dryer Repair)
by rleigh 6/5/2017 9:20:31 AM(UTC)
Inglis dryer won't start (Dryer Repair)
by jkeefe 4/20/2017 2:48:09 AM(UTC)
Amana Dryer won't start, but still gets hot (Dryer Repair)
by halfmoonranch 3/15/2017 9:38:33 AM(UTC)
Dryer won't start (mid-troubleshooting, could use some help) (Dryer Repair)
by OUberLord 3/13/2017 7:15:55 PM(UTC)
Whirlpool Dryer Won't Start (Dryer Repair)
by agjr200hp 2/5/2017 5:36:21 AM(UTC)
