Bkord123
#1 Posted : Sunday, January 5, 2014 7:02:34 AM(UTC)
Bkord123
Hi folks. The high power burner stopped working. I first replaced the switch, nothing. Next the burner itself, still nothing. The range is in great condition so when I open everything up, it all looks clean and organized. I checked continuity on every wire from the burner itself to wherever they ended, and all wires have continuity.
Any ideas at this point? Oh yeah, I have fuses for my house electric, and I replaced the two fuses for the range, just to cover that base. Didn't help. Power at the outlet to the range does in fact get the full 240v. Verified that too.
A year of good karma to the person who can solve this mystery!
#2 Posted : Monday, January 6, 2014 1:10:47 AM(UTC)
Parts for Kenmore Range 79096224408 - AppliancePartsPros.com
If you go to the Sears parts site they have actual part breakdown diagrams.
Unfortunately they do not sghare these with othe parts suppliers.
Here is your wiring diagram.
http://manuals.frigidaire.com/p...pringfield/316417747.pdf
I am not sure which element is the "high power burner" but you should be able to find the problem by unplugging the unit and using a meter to find where the circuit is open.
Bkord123
#3 Posted : Monday, January 6, 2014 5:23:46 AM(UTC)
Bkord123
Originally Posted by: denman Go to Quoted Post
Thank you for the reply. I downloaded the diagram, but unfortunately, I'm approaching the upper limits of my knowledge. When you say to unplug and find where the open circuit is, you mean unplug the range itself and check each wire for continuity? Sorry for the lack of understanding. Like I said, I have basic electrical knowledge, more than the average guy, but not a lot more.
#4 Posted : Monday, January 6, 2014 8:15:55 AM(UTC)
Not a problem.
Yes unplug the unit.
This is the safest way to find your problem.
Then attach one meter lead to one end of the circuit you want to check and leave it there.
Then work your way back along the circuit till you find the open.
