scarey1955
#1 Posted : Monday, December 30, 2013 5:58:37 PM(UTC)
scarey1955
This was kinda mentiioned , on our Viking oven both burners will glow and ignite for several seconds then the left burner weekens and goes out. the igniters stay glowing. Then it totally shuts off and restarts the same thing.
VikTech
#2 Posted : Monday, December 30, 2013 8:19:56 PM(UTC)
VikTech
Check Ignitors for 3-3.5 amps. A weak ignitor will open the valve but only partially.
I'm assuming you mean the flame goes in and out, not the ignitor? This would make sense if weak Ignitors are the cause. If you meant that the ignitor was glowing, then not, then back on... You'd have something weird going on. I'd start by confirming a constant voltage to the ignitor even when not glowing. This would still indicate a bad ignitor(s). If voltage is dropping out your thermostat should be checked.
Ignitor PB040001 replace them both if you're getting less than 3 amps on either.
scarey1955
#3 Posted : Tuesday, December 31, 2013 8:20:06 AM(UTC)
scarey1955
Thankyou! I have 2.6 amps on both igniters and 5.5 amps on the main line. So i will change the igniters and hope this solves the problem.
Viking Oven door opens only 1/2 in. Did not use self -clean (Oven Repair (including Ranges and Cooktops))
by Guest 2/8/2024 1:50:17 PM(UTC)
Viking Oven Wont turn on (Electric) (Oven Repair (including Ranges and Cooktops))
by oRIDDLERo 8/3/2015 12:23:11 PM(UTC)
Viking Oven Door Won't Open (Oven Repair (including Ranges and Cooktops))
by steve aibel 1/9/2014 9:38:36 AM(UTC)
Viking oven one side heats (Oven Repair (including Ranges and Cooktops))
by tbny822 11/16/2013 9:35:08 AM(UTC)
Viking Oven will not stay on (Oven Repair (including Ranges and Cooktops))
by Arlington22207 11/10/2013 4:19:02 PM(UTC)
Viking Oven No PWR (Oven Repair (including Ranges and Cooktops))
by Peter@%@ 3/23/2013 5:39:08 AM(UTC)
Viking Oven Burners Ignite then Shut Off - Please Help - $100 reward! (Oven Repair (including Ranges and Cooktops))
by sepulchral 12/3/2012 9:53:14 AM(UTC)
Viking oven slow to light (Oven Repair (including Ranges and Cooktops))
by alaskachick 8/26/2012 10:54:59 AM(UTC)
viking oven repair (Oven Repair (including Ranges and Cooktops))
by ogarc3 2/23/2012 1:33:23 PM(UTC)
Viking oven turns on by itself (Oven Repair (including Ranges and Cooktops))
by jrschwein 10/16/2011 9:59:11 AM(UTC)
Viking oven door fell off LHS hinge (Oven Repair (including Ranges and Cooktops))
by Boston Viking 10/26/2010 7:03:50 PM(UTC)
Viking Oven Door Lock After Self Clean (Oven Repair (including Ranges and Cooktops))
by bennettjon 1/13/2010 6:04:39 AM(UTC)
Viking Oven Gas Valve Sticking (Oven Repair (including Ranges and Cooktops))
by BIPD818 1/3/2010 11:30:27 PM(UTC)
Viking Oven Burns Everything (Oven Repair (including Ranges and Cooktops))
by pattyjackmore 12/8/2009 4:42:28 PM(UTC)
Viking Oven burners shut off; can't reach desired temperature (Oven Repair (including Ranges and Cooktops))
by MiMiStan 3/30/2009 6:09:56 AM(UTC)
