2 Pages12>
hawaiioption
#1 Posted : Saturday, December 28, 2013 7:42:49 PM(UTC)
hawaiioption
My Kenmore 600 washer agitate, but stop when it should drain and spin.
It has some humming sound.
I bypassed the lid switch and it does same thing--lid switch is fine;
I took off the pump and found the motor does not rotate when the dial is in "spin" and only hear humming sound. But the washer did agitate. Does that mean the motor is good? What could be wrong? Thank you. BTW where can I find model number?
fairbank56
#2 Posted : Sunday, December 29, 2013 4:27:29 AM(UTC)
fairbank56
Groups: Expert
Model number might be under lid either on the panel or the tub cover. We need that number. Set to spin with pump removed and try rotating motor shaft CW by hand as fast as you can while it is humming. If it won't start, remove motor and set on floor and try again. If it still just hums, spin pump shaft by hand again CW. Place your foot on motor when starting as motor may jump if it starts. Don't leave it humming for long as that is bad for the capacitor and motor windings. Motor is probably fine. Problem is most likely the timer.
Eric
hawaiioption
#3 Posted : Monday, December 30, 2013 7:46:16 AM(UTC)
hawaiioption
Thank you Eric,
I will check the number and try what you told me to do tonight. Just a little wondering, why timer problem can course this kind of problem?
Eric
fairbank56
#4 Posted : Monday, December 30, 2013 9:13:50 AM(UTC)
fairbank56
Groups: Expert
The motor runs in the opposite direction for spin than it does for agitate. This is accomplished with the timer reversing polarity to the motor start winding. If one of the swtiches in the timer for the start winding is not making contact and you only have power to the motor run winding but not the start winding, the motor will hum, but won't start. If that is the case, you should be able to start it by hand.
Eric
hawaiioption
#5 Posted : Monday, December 30, 2013 5:20:12 PM(UTC)
hawaiioption
The model number is:29622801.
I removed the motor and tried to rotate it by hand. It does not start and just hum. Is there any way to check the timer directly or what else I should do? (BTW, the SPIN on all the cycles are not working) Thank you.
fairbank56
#6 Posted : Monday, December 30, 2013 5:51:20 PM(UTC)
fairbank56
Groups: Expert
You will have to check voltages at the motor connector. With timer in spin mode, you should have 120vac between the blue and white/black wires as well as between the red and yellow wires.
Eric
hawaiioption
#7 Posted : Tuesday, December 31, 2013 9:54:09 AM(UTC)
hawaiioption
I am going to buy multimeter to take a measurement of it.
Can you let me know what it means if it is 120vac or not and what's next I will do. Just one more step further is ok. Thank you.
Eric
hawaiioption
#8 Posted : Saturday, January 11, 2014 6:00:06 AM(UTC)
hawaiioption
I measured the voltage per your instruction. There is no voltage between the blue and white/black wires as well as between the red and yellow wires.
What should I do next? Thank you.
Eric
Read more: http://forum.appliancepartspros...-spin.html#ixzz2q6On9TO3
http://forum.appliancepartspros.com
fairbank56
#9 Posted : Saturday, January 11, 2014 7:58:00 AM(UTC)
fairbank56
Groups: Expert
You said the motor hums when in spin mode. It can't hum if it doesn't have any power to it. The blue to wht/blk is the run winding, red to yellow is the start winding. If motor is humming, you must be getting power to one of these windings. I think your timer is probably bad but I have little confidence in your voltage tests. When timer is set to spin mode, does the timer advance on it's own?
Eric
hawaiioption
#10 Posted : Saturday, January 11, 2014 11:40:26 AM(UTC)
hawaiioption
Yes, i had the same wondering too. I am going to do it again tonight. The timer just stop at SPIN and does not move.。。
Thank you so much, Eric.
2 Pages12>
