tzdriver
#1 Posted : Friday, December 27, 2013 3:36:28 AM(UTC)
tzdriver
my washer makes noise only when it spins but if I hold the agitator while it is spinning the noise stops.
fairbank56
#2 Posted : Friday, December 27, 2013 4:31:52 AM(UTC)
fairbank56
Groups: Expert
What is the model number of the washer? Post video to youtube so we can hear the noise.
Eric
tzdriver
#3 Posted : Friday, December 27, 2013 5:52:52 AM(UTC)
tzdriver
model no LXR9245EQ1 I have a video I will try to up load it.
Code:
tzdriver
#4 Posted : Friday, December 27, 2013 6:23:48 AM(UTC)
tzdriver
I cant upload the video I will keep trying.
tzdriver
#5 Posted : Friday, December 27, 2013 7:26:18 AM(UTC)
tzdriver
I got the video on you tube under washer noise by Tim Zeiher
thank-you to everybody that can help.
fairbank56
#6 Posted : Friday, December 27, 2013 12:43:59 PM(UTC)
fairbank56
Groups: Expert
I'm afraid that's a worn agitate cam in the gearcase. Unless your prepared to tear the gearcase down, you will need to just replace it.
Whirlpool 3360629 Neutral Drain Transmission - AppliancePartsPros.com
Eric
tzdriver
#7 Posted : Friday, December 27, 2013 3:40:14 PM(UTC)
tzdriver
Eric
thanks for the info Eric. I am not sure what I will do. Maybe just run it until she quits then buy a new washer?
tzdriver
#8 Posted : Friday, January 3, 2014 1:31:44 PM(UTC)
tzdriver
Eric I took the tranny apart and everything looked good so I put it all back to gather and it still makes that noise, how would the agitate cam cause it to make that noise? thanks tzdriver.
fairbank56
#9 Posted : Friday, January 3, 2014 2:22:30 PM(UTC)
fairbank56
Groups: Expert
The agitate cam consists of two parts, the cam and cam follower. The cam follower remains stationary while the cam is rotated a few degrees in either direction to engage or disengage the agitate gear from the agitator shaft. The cam parts can wear to the point that when the agitate gear is lifted to disengage it from the agitator shaft, the cam does not lift it far enough to fully disengage it. The noise you hear is the internal splines of the agitate gear rubbing against the splines on the agitator shaft.
Eric
tzdriver
#10 Posted : Saturday, January 4, 2014 4:08:39 AM(UTC)
tzdriver
Thanks Eric That's what I was thinking. Wanted a 2nd opinion before I bought the parts. Thanks again TZ.
Kenmore- Noise Spinning (Washer Repair)
by lukster 11/22/2013 8:51:43 AM(UTC)
Ge Washer Bearing Noise Spin/click (Washer Repair)
by WHEATEN 4/13/2012 9:59:23 AM(UTC)
