All Wet
#1 Posted : Sunday, December 22, 2013 8:55:00 AM(UTC)
All Wet
Bought this 12-16, 2013. 1 /2 weeks ago. Hooked up new dryer and it melted the main outside on the pole. Replaced the main (100 amp service) $45.00, and then popped the new breaker. Replaced the dryer plug on the wall, it was old anyway but it worked 2 days before it popped the main again. Do the new dryers draw more current than older ones? My house was built in 1968 and has most of the wiring done in 8 ga wire.
#2 Posted : Monday, December 23, 2013 12:19:37 AM(UTC)
Parts for Whirlpool WED4900XW0 Dryer - AppliancePartsPros.com
Here is the install sheet for this unit.
http://www.whirlpool.com/digita...ions%20-%20W10096987.pdf
It calls for a 30 amp double pole (240 volt) circuit.
8 gauge wire should be able to handle a 45 amp circuit.
A 30 amp circuit is normally 10 gauge wire.
I am not sure what is going on here.
If the dryer was pulling too much current it should have popped the dryer's circuit breaker not the mains breaker.
Might be best to get an electrician in.
File Attachment(s):
WED4900.pdf (96kb) downloaded 5 time(s).
All Wet
#3 Posted : Monday, December 23, 2013 11:40:41 AM(UTC)
All Wet
That sounds like the next srep. Seems it should trip the dryer circuit first and not the main. I'm thinking the connection at pole to house needs investigating. Thank you for responding and I hope you and yours have a very Merry Christmas. Bill
