I don't have manual for refrigerator and can't figure out how to hook up water line to the ice maker
Are you talking about the main water supply which hooks to the water inlet valve at the bottom on the back of the unit.
Or are you talking about the line going from the water inlet valve up the back of the unit where it hooks to a junction and goes through the back to the ice maker.
It doesn't actually connect to the ice maker. The water goes into a fill tube and just flows into the ice mold per gravity.
Originally Posted by: woodchuckie ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Are you talking about the main water supply which hooks to the water inlet valve at the bottom on the back of the unit.
It doesn't actually connect to the ice maker. The water goes into a fill tube and just flows into the ice mold per gravity. I'M TALKING ABOUT HOOKING UP TO THE WATER INLET VALVE
It doesn't actually connect to the ice maker. The water goes into a fill tube and just flows into the ice mold per gravity. IT HOOKS UP ON THE BOTTOM AT THE VALVE SOMEHOW
