Jcb63
#1 Posted : Monday, December 16, 2013 5:13:55 PM(UTC)
Jcb63
My KitchenAid fridge/freezer "over temp" light keeps coming on, and indeed the freezer shows temp of 25-30 degrees (f) which is way above set point. I push reset button but it comes on again soon after. This started happening right around the time I accidentally shut the water off to the freezer's ice maker. I have since turned the water back on but the ice maker stopped making ice and the over temp reset button keeps coming on. I also hit the "power" button hoping for some kind of "reboot" but no luck.
Any advice would be appreciated. Thank you in advance.
#2 Posted : Tuesday, December 17, 2013 2:34:52 AM(UTC)
Check the condensing coils under the fridg for a lint clog and check the back and verify the condensing fan motor is running. If ok and the freezer fan is running, you probably have refrigeration problems, bad compressor/ refrigerant leak.
