chevzilla
#1 Posted : Thursday, December 12, 2013 8:18:09 PM(UTC)
chevzilla
OK...So I have been working on this problem since right before Thanksgiving.
My fridge wont get below 45F. I found that the previous owner had zip tied the defusser in the open position before we got the fridge. I replaced the defusser thinking that would cure the problem but to no avail. So tonite I replaced the fridge side thermostat and the new defusser wont open. Im just wondering if anyone may have an idea as to what to do next? The freezer is going below zero. I tried closing the door switch also and no change other than the lights going off.
#2 Posted : Friday, December 13, 2013 2:51:29 AM(UTC)
It has a baffle test procedure.
File Attachment(s):
KSRB25.pdf (608kb) downloaded 5 time(s).
chevzilla
#3 Posted : Saturday, December 14, 2013 3:03:53 PM(UTC)
chevzilla
So first let me say thanks for the paperwork.
So I tested all the new items and they seem to be up to par. I have noticed the the defusser wont open... I can slide the vane open but it does close by itself and wont reopen. Is the defusser not working properly? Is there a signal from another piece that is supposed to cause it to open?
#4 Posted : Sunday, December 15, 2013 4:13:11 AM(UTC)
Did you try the baffle test given in the tech sheet?
chevzilla
#5 Posted : Sunday, December 15, 2013 11:13:00 AM(UTC)
chevzilla
I tried the test and the defusser was acting sluggish. It closed but didnt reopen
