Dishwasher went dead halfway through cycle. I replaced the fuse and control board. Power is going to the unit however nothing is lit up, no sound, still dead. :( Yes...it is plugged in.
I cannot find any info on this unit, tried here and the Sears site. Sears model numbers are usually 3 digits, a period and then an additional 8 digits.
How do you know that power is going to the unit?
Have you checked the door latch switches?
Did you check the fuse with a meter before replacing it? |
THIS FORUM IS DEAD!!!!!!! |
