2 Pages12>
pdhughes
#1 Posted : Wednesday, December 11, 2013 4:54:42 PM(UTC)
pdhughes
My GE side by side was cooling but not getting cold enough. Been through two repair companies & one month later still not right. I vacuumed out hair, fur,dust, from coils.
Compressor is running, warm & vibrating . Condenser fan runs. Evaporator fan runs. The bi metal was bad & was replaced. Defrost heater was supposedly ok. No change. Next motherboard replaced. No change. Freezer coil frost up. Next company said it was the defrost heater and thermistor. Wanted $300 to fix. Said bye bye to that company.
I ordered the parts from you (alot less than $300). I installed the defrost heater and thermistor. Fresh food side is about 38 degrees freezer stays at 20 maybe down to 15 degrees. What else?
AntonioStogsdill
#2 Posted : Wednesday, December 11, 2013 8:53:44 PM(UTC)
AntonioStogsdill
That is a bit complicated i guess.
Xtreme Nitro
#3 Posted : Thursday, December 12, 2013 3:04:45 AM(UTC)
Unplug fridg. and remove the 3 pin power connector on the bottom of the motherboard. Put a wire jumper between the connector pins marked on the motherboard line and def.
Plug in fridg. ,it should now defrost, if not, you have a problem with the defrost circuit.
pdhughes
#4 Posted : Thursday, December 12, 2013 5:38:09 AM(UTC)
pdhughes
Hi Richappy
If it turns out to be a problem with the defrost circuit is that an expensive repair?
I also don't think I have a jump line. I am not an electrician or repair person. Just a lady trying to either get fridge fixed by repair techs who don't do a real diagnosis or fix it myself. Or not waste more money & buy a new one, which I can't afford. I willing to try. Where would I get a jump line, hardware store?
pdhughes
#5 Posted : Thursday, December 12, 2013 6:13:06 AM(UTC)
pdhughes
Hi Richappy
When connecting the defrost heater, does it matter which way the wire end connector clip onto the heater tabs? I wanted to be sure, since the repair tech took out the part and I had no reference as far as the connections.
#6 Posted : Thursday, December 12, 2013 8:03:49 AM(UTC)
No, the heaters are non-polar. You may have connected the wire terminal in the wrong slot of the heater, there are two of them, one blank.
pdhughes
#7 Posted : Thursday, December 12, 2013 8:27:42 AM(UTC)
pdhughes
Hi Richappy
i got the connectors on the tabs. I saw the empty side. What about the repair cost of the faulty defrost circuit?
#8 Posted : Friday, December 13, 2013 1:01:49 AM(UTC)
Try the test I mentioned before, use a piece of wire. That will determine if your motherboard is bad. Sometimes bad motherboards are shipped.
#9 Posted : Friday, December 13, 2013 1:03:45 AM(UTC)
If you get a partial defrost, the thermistor might be bad, a thin, white item clipped to the top of the evaporator.
pdhughes
#10 Posted : Friday, December 13, 2013 6:13:49 AM(UTC)
pdhughes
Hi Richappy
I replaced the freezer thermistor when I replaced the defrost heater.
so bi metal, defrost heater, thermistor, motherboard all replaced. Any suggestions
Guest (5)
GE refrigerator not freezing (Refrigerator & Freezer Repair)
by aprig812 1/30/2012 4:17:09 PM(UTC)
2 Pages12>
