Tom@devaneycpa.com
#1 Posted : Wednesday, December 11, 2013 7:39:07 AM(UTC)
Tom@devaneycpa.com
Washer is level has been working fine, recently started leaping immediately after the spin cycle before shutting off.
fairbank56
#2 Posted : Wednesday, December 11, 2013 10:41:20 AM(UTC)
fairbank56
Groups: Expert
Get some sil-glyde grease. Remove washer cabinet and place a small dab of grease on inside vertical surface of the brake hub. Make sure to apply it on the hub surface where the brake pads are currently not in contact with.
Eric
UserPostedImage
