Hank22
#1 Posted : Tuesday, December 10, 2013 9:34:31 AM(UTC)
Hank22
I recently began having issues with the Bosch not cleaning well and the water not heating during wash cycle. We have an on-demand water heater so normally the water does not heat during the fill cycle because it is to short of duration for the on-demand water heater to provide hot water. But it had worked well for the last 6 years with this same setup. The sanitize cycle works just fine, so the element is good. Any thoughts or suggestions would be helpful. Thanks Hank22
Hank22
#2 Posted : Sunday, December 22, 2013 12:06:51 AM(UTC)
Hank22
I replaced the entire heater assemble. This part contains the heater element, pressure switch and thermistor. It now appears to work intermittently. I tested the old module after removing it and it appears to be good. I am beginning to think the problem is in the control module. Does anyone have a copy of the troubleshooting manual for this model? Or any suggestions on further troubleshooting?
Hank22
#3 Posted : Tuesday, December 24, 2013 4:20:14 PM(UTC)
Hank22
Well problem appears to be resolved with the installation of the control module. No more E1 alarms. Water heats and I show an E0 indicator when doing the self test, which I assume to mean no alarms. If I can I will scan the meager schematic and troubleshooting information that I found folded up in the base of the dishwasher.
markonah
#4 Posted : Thursday, February 27, 2014 8:22:50 PM(UTC)
markonah
good luck if problem resolved
UserPostedImage
Guest (4)
