djones3158
#1 Posted : Tuesday, December 10, 2013 7:58:25 AM(UTC)
djones3158
is there any way to ck oil level in transmission on fav6800. i'm doing a outer tub rebuild and noticed a little oil seeping from seal while trans is sitting on floor{waiting on parts} oil looks ok but haven't seen anyone on here replace trans seal. trans turns smooth with slight resistance and seemed to be working fine. i just like to check things out before i put it all back together....thanks. and thanks for all the posts on outer tub rebuild!!
rogair
#2 Posted : Friday, September 12, 2014 4:50:16 PM(UTC)
rogair
I know you're long gone - Just saw the post.
If you pull the tranny out, clean outside & hold up to light/sunlight while on its side. You can see through plastic case. Should be 1/3 full of clean oil - not soapy oil or milkshake. I have drilled a hole in a recessed location, changed/refilled oil, & sealed with a stainless steel sheet metal screw.
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
How to test a direct-drive transmission? (Washer Repair)
by DIY_Again! 3/20/2023 9:12:52 AM(UTC)
Ruined 3 splutches, problem was the transmission (Washer Repair)
by Greg Shay 9/28/2022 5:52:48 AM(UTC)
Maytag top load washer leaking oil from transmission (Washer Repair)
by Rdchapman2 2/27/2022 1:15:02 PM(UTC)
Whirlpool Cabrio Washing Machine replaced transmission (Washer Repair)
by reggiebliss 8/26/2021 7:31:39 PM(UTC)
Can't pull out Motor/Transmission in Whirlpool Washer (Washer Repair)
by TWash2 6/16/2021 6:42:02 PM(UTC)
Whirlpool Washer LSQ8543JT1 Transmission Gear (Washer Repair)
by wvdiesel 2/20/2021 9:55:50 AM(UTC)
Maytag Top-Loading Washer Transmission Issue? (MVWC565FW) (Washer Repair)
by Beerski 11/13/2020 10:59:24 AM(UTC)
Speed Queen washer transmission repair (Washer Repair)
by thorning 4/2/2018 11:07:15 AM(UTC)
Clearing hole in new transmission (Washer Repair)
by Jimbobaloue 3/28/2018 6:23:59 PM(UTC)
Motor or Transmission (Washer Repair)
by asd643 10/3/2017 1:09:42 PM(UTC)
Kenmore Washer, Suspect transmission (Washer Repair)
by jmrec100 5/12/2017 3:03:16 PM(UTC)
Transmission Oil Type (Washer Repair)
by RdPope01 7/13/2016 5:43:30 AM(UTC)
Kenmore washer leaking water on transmission (Washer Repair)
by arttruji 6/30/2016 11:55:27 AM(UTC)
Maytag Washer - Transmission Gear Oil & Sealant (Washer Repair)
by rips 4/17/2016 6:15:08 PM(UTC)
