alcal
#1 Posted : Saturday, December 7, 2013 6:31:06 AM(UTC)
alcal
Hello all. If I missed a tread where this problem has already been covered I apologize. I inherited a Kenmore top freezer which has stopped cooling on it's own. If I turn the cold control knob manually the compressor kicks on and everything gets cold as it should (I changed out the cold control hoping that was the problem- it wasn't). The defrost timer seems to be working fine. Heat exchanger is clean and there wasn't a problem with excess frost before the unit stopped working properly. Any ideas are greatly appreciated!
#2 Posted : Sunday, December 8, 2013 3:48:00 AM(UTC)
Most probable problem is a burnt wire behind the control panel.
alcal
#3 Posted : Sunday, December 8, 2013 9:18:50 AM(UTC)
alcal
I was hoping you could point me toward the control panel. Customer service at APP couldn't. Do you have a hunch as to which component the wire would be running from/to? I should add; this fridge sits in the garage. It was fine last winter, but could the cold be bothering a thermostat? I saw on another thread were a garage kit is available for some models. My serial # is LA13814906
Thanks again for your help. After replacing a perfectly fine cold control I'd like not to throw good $ after bad.
#4 Posted : Sunday, December 8, 2013 10:06:15 AM(UTC)
That's your problem, too cold in the garage and hard on the compressor.
alcal
#5 Posted : Sunday, December 8, 2013 10:19:25 AM(UTC)
alcal
Urgh, that sounds like a problem. It'd be better if something was broke. I'm in MD and the garage is only 40's (when I've checked). With all due respect it's hard to believe that cold is the problem b/c I'm sure I'm not the only one with a garage fridge.
Would one of those garage kits work for me? Or is this fridge hopeless?
alcal
#6 Posted : Sunday, December 8, 2013 11:36:51 AM(UTC)
alcal
Richappy, Thanks again for taking your time to read my dribble. Santa will surely be taking note.
I had an idea about the cold garage affecting fridge performance. Would putting a lightbulb down by the compressor help?
#7 Posted : Monday, December 9, 2013 12:59:35 AM(UTC)
NO, your differential cold control will simply not work, too cold. You can buy a constant differential control that will work, part #3030-505
alcal
#8 Posted : Monday, December 9, 2013 5:32:15 AM(UTC)
alcal
I'll give it a try.
