andrewgol
#1 Posted : Friday, December 6, 2013 12:01:18 PM(UTC)
andrewgol
My Washer filled and then stopped working. I was told it was probably the lid switch or the control panel. I have pulled the lid switch. It has four leads: Neutral, line, motor machine. Which leads can I connect to test if lid switch is bad?
fairbank56
#2 Posted : Friday, December 6, 2013 1:05:53 PM(UTC)
fairbank56
Groups: Expert
Jump line to motor.
Eric
andrewgol
#3 Posted : Friday, December 6, 2013 4:00:38 PM(UTC)
andrewgol
By jumping line to motor, the washer worked. Thanks for your help. Now I will order the part!
fairbank56
#4 Posted : Friday, December 6, 2013 4:24:15 PM(UTC)
fairbank56
Groups: Expert
Unusual for it to fail that way. Usually, the fuse link blows and then nothing will work including fill. Do you hear the switch click when opening/closing the lid? May be a problem with the lid cam and plunger. Check continuity on the lid switch while operating it manually.
Eric
