first day we hooked it up worked great bakes bread pies no problems. Thanksgiving day put turkey in top oven convection put on broil 500degrees 8 minutes or so. turned broil off put to bakes 350 degrees, after a few minutes oven turns off. It will start but in a minute you hear a click in the control panel a few seconds later oven turns off. Code F2 EO It wants to work
Here are your parts Parts for Whirlpool KEBS247DWH6 Wall Oven - AppliancePartsPros.comSee the attachment for the tech sheet. This will be a pain/gamble to fix. The problem could be a bad control panel/keypad, a bad control board or a bad connection between the two. What exactly do you do to get the unit to re-start? This may give some clue as to the cause. Does the cooling fan run like it has in the past? If you just use bake from the start does it run OK? |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts Parts for Whirlpool KEBS247DWH6 Wall Oven - AppliancePartsPros.comSee the attachment for the tech sheet. This will be a pain/gamble to fix. The problem could be a bad control panel/keypad, a bad control board or a bad connection between the two. What exactly do you do to get the unit to re-start? This may give some clue as to the cause. Does the cooling fan run like it has in the past? If you just use bake from the start does it run OK? Hi thank you so much the cooling fan runs the same the oven doesn't run on anything bake,broil nothing
Sorry now I am confused. You said " It will start but in a minute you hear a click in the control panel a few seconds later oven turns off". You last post said "the oven doesn't run on anything bake,broil nothing"
Need more info on what is happening. |
Originally Posted by: denman  Sorry now I am confused. You said " It will start but in a minute you hear a click in the control panel a few seconds later oven turns off". You last post said "the oven doesn't run on anything bake,broil nothing"
Need more info on what is happening. I'm sorry it dous run for a few minutes then turns off of broil,bake ect.
Still need more info,
How do you get it to start again? Do you have to wait for it to cool down?
This is an unusual problem so pinpointing the cause will take a lot of troubleshooting. It does sound like a connection problem which shows up when parts get warm but if you do not have to let the unit cool down then that does not make sense.
This may be one for a pro to come in and check out. |
This may be one for a pro to come in and check out. The oven doesn't ever get hot enouph I push bake top or the bottom set temp for 350degrees hit start,everything starts normal a minute later or so you hear a small click and the oven automatically turns off then code appears F2 EO so I hit cancel to clear the codes.There is really nothing the fan can cool down the oven turns off before it can get hot enouph. It seems this all started after we put the turkey in the oven on broil for about 8 Minutes. then turned around to bake could the broiler of gotten to hot and caused the problem? Becauce the day before I baked pies and bread and it worked just fine.
Your last post said that this happens with both ovens and at about the same time so I also doubt it is a bad connection caused by connectors heating up. The time of when the error would be different for each oven.
The tech sheet shows that the control panel is monitored for connection all the time. Since you only get an error when using the ovens I would replace the control board/timer.
This is a gamble but is the more likely of the two parts. |
