Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) That is correct. You should be able to start just a spin cycle to pump the water out. Then replace that hose back to the switch and see what happens. wm1812cw is the model #. so what i did was drag it out to back porch and dump it because i dont have just a spin cycle had to be a rinse and spin and again just fills with water. After i dump it drag it in and hook back up ran a rinse and spin and shut it off when water got to door, I know from past the water turns on and off alternating spin direction so steady on water does not operate correctly. I did however notice that the suuport leg to drum is off on that side(probably me when i replaced drum shaft) which may have caused hose to disconnect. I think at this point maybe order new air valve thing?
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I am about to order that is there anything else I may need? my water fill valves seem to leak a little now and then i see water coming out from underneath but only during cycle and I cant seem to find that valve on parts list
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) ok on order i will update as repairs are made. Thank you so much for your help now if i can only remember my info when bought parts for door seal and my dishwasher to sign in lol
You are very welcome, keep me posted!
Originally Posted by: Appliance Ninja ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) You are very welcome, keep me posted! ok part came very fast just like it always does from here and had it installed 2 days after order. The sensor was the problem and now washer working great. *** there was water in the tub so I had to trick the sensor on first cycle by blowing air through line pinching line then hook back to sensor creating initial pressure (only because I didn't want to drain it again)
Glad you got it up and running, nice work!
