2 Pages<12
mojuave
#11 Posted : Wednesday, November 20, 2013 12:59:08 PM(UTC)
mojuave
Originally Posted by: Appliance Ninja Go to Quoted Post
That is correct. You should be able to start just a spin cycle to pump the water out. Then replace that hose back to the switch and see what happens.
wm1812cw is the model #. so what i did was drag it out to back porch and dump it because i dont have just a spin cycle had to be a rinse and spin and again just fills with water. After i dump it drag it in and hook back up ran a rinse and spin and shut it off when water got to door, I know from past the water turns on and off alternating spin direction so steady on water does not operate correctly. I did however notice that the suuport leg to drum is off on that side(probably me when i replaced drum shaft) which may have caused hose to disconnect. I think at this point maybe order new air valve thing?
Appliance Ninja
#12 Posted : Wednesday, November 20, 2013 1:26:33 PM(UTC)
Appliance Ninja
If it finally did shut off bur still overfilled, I do believe the pressure switch may need to be replaced. The correct one for your model is available at the link below.
LG 6601ER1006A Switch Assm.,sensor S - AppliancePartsPros.com
mojuave
#13 Posted : Thursday, November 21, 2013 6:38:50 AM(UTC)
mojuave
I am about to order that is there anything else I may need? my water fill valves seem to leak a little now and then i see water coming out from underneath but only during cycle and I cant seem to find that valve on parts list
Appliance Ninja
#14 Posted : Thursday, November 21, 2013 6:43:34 AM(UTC)
Appliance Ninja
Both valves for your model are available below. I can think of no other parts you may need.
LG 5221ER1003A Water Inlet Valve Assembly - AppliancePartsPros.com
LG 5220FR2006H Water Inlet Valve Assembly - AppliancePartsPros.com
mojuave
#15 Posted : Thursday, November 21, 2013 6:57:06 AM(UTC)
mojuave
ok on order i will update as repairs are made. Thank you so much for your help now if i can only remember my info when bought parts for door seal and my dishwasher to sign in lol
Appliance Ninja
#16 Posted : Thursday, November 21, 2013 7:07:53 AM(UTC)
Appliance Ninja
You are very welcome, keep me posted!
mojuave
#17 Posted : Monday, November 25, 2013 5:57:34 AM(UTC)
mojuave
ok part came very fast just like it always does from here and had it installed 2 days after order. The sensor was the problem and now washer working great.
*** there was water in the tub so I had to trick the sensor on first cycle by blowing air through line pinching line then hook back to sensor creating initial pressure (only because I didn't want to drain it again)
Appliance Ninja
#18 Posted : Monday, November 25, 2013 6:35:33 AM(UTC)
Appliance Ninja
Glad you got it up and running, nice work!
2 Pages<12
