2 Pages12>
Capebouy
#1 Posted : Tuesday, November 19, 2013 9:50:39 AM(UTC)
Capebouy
This is a reply to Appliance Ninja's questions about the "white" fuse in the front of the control panel of my front loader washer. The fuse is good as I checked it today. My washer fills, runs a very short cycle and does not spin. The drum does tumble from side to side. As mentioned before I replaced the door switch and timer switch last month. The machine ran well for a couple of weeks, and this problem began.
Any help would be greatly appreciated.
Appliance Ninja
#2 Posted : Tuesday, November 19, 2013 11:47:08 AM(UTC)
Appliance Ninja
Thank you for the fuse information. Now, a question about the timer. It advances through the cycle very fast and there is no spin in any part of the cycle? Does it drain?
Capebouy
#3 Posted : Tuesday, November 19, 2013 11:57:48 AM(UTC)
Capebouy
Hi. Yes it does drain . I cleaned out the coin trap and evac.hose as well.
Appliance Ninja
#4 Posted : Tuesday, November 19, 2013 12:02:57 PM(UTC)
Appliance Ninja
Okay, and how about the timer, it advances very rapidly, faster than normal?
Capebouy
#5 Posted : Tuesday, November 19, 2013 12:10:46 PM(UTC)
Capebouy
I have not watched the progression,but the cycle is very quick. It does not spin,but does drain.
Appliance Ninja
#6 Posted : Tuesday, November 19, 2013 12:13:52 PM(UTC)
Appliance Ninja
Okay, and if you set it to a spin cycle and start it, allow it to run for about 3 minutes and stop it, does the door open right away or remain locked for about 90 seconds?
Capebouy
#7 Posted : Tuesday, November 19, 2013 12:17:56 PM(UTC)
Capebouy
I will run that test now. I have to hook up and install board will let you know it 15 min. Thanks!!!!
Appliance Ninja
#8 Posted : Tuesday, November 19, 2013 12:19:01 PM(UTC)
Appliance Ninja
Thank you!
Capebouy
#9 Posted : Tuesday, November 19, 2013 12:29:56 PM(UTC)
Capebouy
Hi, The door opens right away. after cycle runs out.
Appliance Ninja
#10 Posted : Tuesday, November 19, 2013 12:33:40 PM(UTC)
Appliance Ninja
Okay, so the door switch is not locking. Either the wax motor is not getting power or it is faulty. Can you set the machine to a spin cycle and test that wax motor for 120 VAC, accessing it from the bottom access panel?
2 Pages12>
