tpskipper
#1 Posted : Tuesday, November 19, 2013 7:50:08 AM(UTC)
tpskipper
washer starts on wash cycle for 5 minutes then stops and gives me f 05 reading which is a water temperature sensor (ntc) replaced it and still get same results. any ideas? anyone
Appliance Ninja
#2 Posted : Tuesday, November 19, 2013 7:56:50 AM(UTC)
Appliance Ninja
There is likely an issue with the wiring harness or connection at the control. If you have a meter to test resistance, locate the wiring harness from that sensor and test its resistance, looking for around 12k ohms at room temperature. If it is much off from that, the harness likely has a break in the wire.
tpskipper
#3 Posted : Tuesday, November 19, 2013 10:39:39 AM(UTC)
tpskipper
where do i locate this control, thx
Appliance Ninja
#4 Posted : Tuesday, November 19, 2013 10:53:00 AM(UTC)
Appliance Ninja
Sorry, that control is mounted under the top panel. There are three screws along the rear edge of the panel, once removed it will pull back and off. The control is mounted at the back of the machine, right in the center. The plug for that thermistor is labeled TH on that board and has two wires in it. Remove that connector from the board and measure the resistance between those two wires.
tpskipper
#5 Posted : Tuesday, November 19, 2013 1:13:53 PM(UTC)
tpskipper
thanks ninja gonna look that up right now.really appreciate your knowledge
Appliance Ninja
#6 Posted : Tuesday, November 19, 2013 1:28:54 PM(UTC)
Appliance Ninja
You are very welcome, let me know what you read with that test.
