2 Pages12>
Ruey
#1 Posted : 11 years ago
Ruey
Freezer will not cool. High temperature light on the door panel stays on.
Appliance Ninja
#2 Posted : 11 years ago
Appliance Ninja
Can you hear the compressor running or tell if it is hot or cold to the touch?
Ruey
#3 Posted : 11 years ago
Ruey
Appliance Ninja, The compressor is warm to the touch and I'm not sure if it is running.
Appliance Ninja
#4 Posted : 11 years ago
Appliance Ninja
Is the panel at the back on the bottom, inside the freezer cold? Can you hear a fan running inside the freezer?
Ruey
#5 Posted : 11 years ago
Ruey
Appliance Ninja, The fan is running but the panel is not cold.
Appliance Ninja
#6 Posted : 11 years ago
Appliance Ninja
Okay, so if the fan is running, the compressor should be running. Can you feel it vibrate at all? On the side of the compressor is an electrical component that starts the compressor. If the compressor is warm but not vibrating, that part may be faulty. Can you tell if the compressor is vibrating at all?
Ruey
#7 Posted : 11 years ago
Ruey
Appliance Ninja
Tha compresor is warm but not vibrating.
Appliance Ninja
#8 Posted : 11 years ago
Appliance Ninja
Okay, so if you unplug the freezer and remove the electrical box on the side of the compressor (it will pull off) and shake it, does it rattle?
Ruey
#9 Posted : 11 years ago
Ruey
Appliance Ninga
I removed the box, it does not rattle
Appliance Ninja
#10 Posted : 11 years ago
Appliance Ninja
Okay, that is not good. Since the compressor is warm, we know it is getting power. Since it is not running, the compressor may be bad or that starter may be bad. Usually, when they fail, they will rattle, but not always. Do you have a meter to test resistance with?
LG Fridge - Air condensing at back of freezer (Refrigerator & Freezer Repair)
by Guest 8 months ago
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 8 months ago
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
Mysterious leak -Top Freezer w/Ice maker (Refrigerator & Freezer Repair)
by St.B 8 months ago
GE bottom freezer model #: PFE28KBLTS not cooling well and no ice (Refrigerator & Freezer Repair)
by Danny1976 9 months ago
GE bottom freezer not cooling well and no ice (Refrigerator & Freezer Repair)
by Guest 9 months ago
Ice block in freezer (Refrigerator & Freezer Repair)
by bassbuddy25 9 months ago
Freezer is cooling ok- top shelves in fridge ok, lower shelves in fridge too warm (Refrigerator & Freezer Repair)
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 9 months ago
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 10 months ago
Freezer Help from Whirlpool Unit (Refrigerator & Freezer Repair)
by Guest 10 months ago
Water Dribbing into Freezer (Refrigerator & Freezer Repair)
by mbc320 10 months ago
KitchenAid freezer gasket needed (Refrigerator & Freezer Repair)
by Kris Ballew 10 months ago
Samsung Rs261MDWP Freezer Evap fan (Refrigerator & Freezer Repair)
by Jben04 10 months ago
Electrolux fridge compartment not cooling, freezer is cold (Refrigerator & Freezer Repair)
by Minthook 10 months ago
2 Pages12>
