Do you have a meter you can test the door switch with and inspect the control at the same time while the control panel is open?
I don' t have a meter, but do you think that is the issue? Can I bypass the switch?
You can bypass the switch, yes. Bypass the switch with the white wires and see if the error displays with the next cycle.
DW Repair
(Dishwasher Repair)
by Sumold
3/18/2011 12:38:13 PM(UTC)
