giroux68
#1 Posted : Friday, November 15, 2013 1:23:44 PM(UTC)
giroux68
the front right burner will not turn off. unplugged and waited about 10 minutes and it turned back on to high when plugged back in. Should I start with the controller or the burner itself?
Appliance Ninja
#2 Posted : Friday, November 15, 2013 1:28:39 PM(UTC)
Appliance Ninja
The burner gets its power from the relay board. So, if it will not shut off, the relay for that burner has welded contacts. The correct relay board for your unit is available at the link below.
Frigidaire 316442102 Board - AppliancePartsPros.com
giroux68
#3 Posted : Friday, November 15, 2013 4:22:03 PM(UTC)
giroux68
thanks. do you know the part number for the multi size burner? 7909912340b model number?
Appliance Ninja
#4 Posted : Friday, November 15, 2013 4:24:16 PM(UTC)
Appliance Ninja
