ROCKY8899
#1 Posted : Friday, November 15, 2013 2:52:31 AM(UTC)
ROCKY8899
Looking for some guidance. Came home and found fridge not cooling. Fortunately in time to save the contents! I am hearing a clicking noise from time to time and asking if that would be a faulty defrost timer causing this?
Appliance Ninja
#2 Posted : Friday, November 15, 2013 6:53:08 AM(UTC)
Appliance Ninja
The clicking you are hearing is likely from the compressor's start device, mounted on the left side of the compressor. That part is simply pushed on to the compressor and will pull off. Be sure the refrigerator is unplugged before removing it. Once off, shake the start device and if it rattles, which I suspect it will, replace it. The start device is shown as number 15 in the diagram and the replacement is available below.
http://www.appliancepartspros.c...e-8201799-ap3873993.html
Appliance Ninja attached the following image(s):
#3 Posted : Friday, November 15, 2013 8:50:34 AM(UTC)
If the new start device looks the same as the old one, just make a diagram of where all the wires go before you replace it.
ROCKY8899
#4 Posted : Sunday, November 17, 2013 4:31:50 AM(UTC)
ROCKY8899
Appliance Ninja - you are the master!
Problem was exactly as you stated. Found a parts store Saturday and had the fridge back up running and stocked by the afternoon. Saved the weekend cookout!
Thought I was going to spend the weekend chasing down a fridge from Craigslist!
Appliance Ninja
#5 Posted : Sunday, November 17, 2013 6:46:57 AM(UTC)
Appliance Ninja
That is great news, nice work! I am glad you got it up and going quickly. be sure to clean the condenser coils down there, too. If they get dirty, they don't dissipate the heat well and can lead to that type of failure. Have a great Sunday!
