Originally Posted by: Appliance Ninja  Okay, if you cannot get the old pin out, the harness will indeed need to be replaced. Thanks for the help. Do you know if there a video or manual instructions available on line for replacing a harness?
There is not, but basically you would need to separate the doors so you have access to the wires between the control area and the components underneath and then it is just a matter of swapping connectors. If you lay the machine on its back, it is much easier.
Originally Posted by: Appliance Ninja  Okay, if you cannot get the old pin out, the harness will indeed need to be replaced. OK. Got pin out; replaced control board and thermal fuse; diswasher works fine. Thanks for the help.
That is great news, very well done! Thank you for taking the time to update, I appreciate that!
